Brevs
Message 41 of 43
Re: TP-LINK Archer VR900 AC 1900 Wireless Dual Band Gigabit VDSL2/ADSL2+ Modem Router
@lookalikey wrote:
solved this.... had to set the region to UK in the System Tools > Time Settings screen under advanced... then bt sport all works fine...
Top man, worked for me. I would have spent hours trying to work this out without your posting, great work and thank you. The thought of ringing BT filled me with absolute dread and you have saved me from that!!
mccanno
Message 42 of 43
To cooperman
You sound like you have the same setup as I do,  I just want to confirm that you do not have another modem, you are just plugging this straight into your telephone wall socket and you are up and running yes?
Tags (1)
cooperman
Message 43 of 43
Yes, it's a one box system and was very easy to setup to replace the HH5. It has superb Wifi range and 4 Gigabit Ethernet ports.
