licquorice
Message 11 of 36
Re: TP-LINK TD-W9980 Set Up
@markah67 wrote:
Not a lot!! I also just went into Diagnostics and it's saying WAN interface not configured.
You have set the Operation mode to xDSL modem router mode rather than Wireless router mode haven't you?
markah67
Message 12 of 36
Should there be anything in PPP Username and Password? I tried to change to CHAP but it wouldn't allow me.
markah67
Message 13 of 36
Operation Mode is xDSL Modem Router Mode
licquorice
Message 14 of 36
Yes, you need to enter homehub@btbroadband.com and BT in password
Sorry, assumed you had already entered that during setup.
markah67
Message 15 of 36
I did but without the password as I had seen posts saying the password was not necessary and it allowed me to carry on. I entered the above as you said and changed to CHAP and now it has taken me to the xDSL WAN interface page which is just constantly refreshing and the Status says connecting.
licquorice
Message 16 of 36
Hmm,  try setting Authentication back to auto.
markah67
Message 17 of 36
It says This Vlan ID has existed try another one!! Goodness me this is not as easy as I thought it would be!!
licquorice
Message 18 of 36
If that fails, set the device back to factory defaults in system tools and run through the Quick Setup again.
markah67
Message 19 of 36
Yes that was going to be my next step. At least I have the firmware update downloaded now!!
licquorice
Message 20 of 36
Smiley Happy  Keep an eye out for further firmware updates, there is currently a beta test version for G.Inp that is expected to be rolled out shortly.
