Indrid
Message 1 of 3
TP-LINK TD-W9980 connection help
Hello,
My HomeHub3 recently failed and I've bought this to try and replace it for Infinity 2. Problem is I can't get it working...
All of the lights are on as they should be, but the set-up wizard always fails citing WAN issues.
I've tried PPPoA and PPPoE (it defaulted to PPPoA), does it matter?
Tried Auto_Auth and CHAP.
Under Network > WAN Settings IP/Mask, Gateway and DNS are all 0.0.0.0 and Status is DSL Disabled.
Under the main Status page though everything seems fine. It says Line Status: Connected with an Upstream and Downstream listed etc.
Any help? Thanks.
2 REPLIES 2
Keith_Beddoe
Message 2 of 3
Re: TP-LINK TD-W9980 connection help
Are you plugging it directly into the DSL socket that the Openreach modem was plugged into?
This post should help.
https://community.bt.com/t5/Other-Broadband-Discussions/TP-link-modem-not-working-after-BT-broadband...
One for user @licquorice
Indrid
Message 3 of 3
Sorry, I got it working immediately after posting this.
For some reason the Quick Setup from the CD was not actually applying any of the settings for some reason.  When I ran the Quick Setup from the router's interface it worked fine.
