Expert
Message 1 of 29
TP-LINK TD-W9980 on Infinity 2
I want to switch to a TP-LINK TD-W9980 on my Infinity 2 connection to try and get around all the problems with the Home Hub 5.  What settings do I need?
I can see the bthomehub@btinternet.com username on the Home Hub 5 configuration
But there is also a box to check for VLAN ID
Then PPPoE/Dynamic ID/Static ID/Bridge
Those seem to be the only settings unless more in Advanced.
I would appreciate any advice on the settings.
MB
28 REPLIES 28
Message 2 of 29
Re: TP-LINK TD-W9980 on Infinity 2
PPoE and VLAN101 are required.
Edit: Will be interested to hear your experience of the 9980, I am considering buying one when we get infinity shortly.
Expert
Message 3 of 29
I have posted a message on the TP-Link forum to see if I can get any suggestions on settings.
Only comment so far is that all the leads are ridiculously short.  The lead to the phone line does not matter because I can use the one from the BT Home Hub 5 but the power supply is a nuisance because I like to have the hub on the top shelf above the PC so the WiFi gets around the house OK.
MB
Message 4 of 29
Just the PPPoE login should work - you only need the VLAN ID set if you use BT TV over Infinity.
Message 5 of 29
Hmm, all the reviews I've read indicate that the VLAN needs to be set to 101 for it to work with Infinity
Message 6 of 29
Not on my Cisco 1841.  I only need to set the VLAN ID when I'm using multicast channels on TV.
Message 7 of 29
Maybe all the reviewers had BT TV Smiley Wink
Edit: I have read the same for the ASUS and Billion VDSL routers
Message 8 of 29
@JMB
Did you manage to get it working?
Expert
Message 9 of 29
@licquorice wrote:
@JMB
Not yet
I posted a message on the TP-LINK's site forum and sent their support people an EMail.
MB
Distinguished Guru
Message 10 of 29
If you look on wiki.kitz.co.uk there's a TD-W9980 QuickSetup it says you have to use VLAN 101
There's also a review.
If not, I'll try again 🙂
