Message 1 of 4
TP-Link TD-W9970 and bt mini connector kits
Quick question. Does anyone know if these work together. I'm thinking of ditching the smart hub and always see this router as a suggestion on the forums.
I have this setup as master socket in attached garage and so I can feed Ethernet to son's xbox upstairs.
3 REPLIES 3
Message 2 of 4
Re: TP-Link TD-W9970 and bt mini connector kits
The mini connectors are just powerline adaptors so won't care what the source of the Ethernet signal is.
Message 3 of 4
Welcome to this user forum.
There should be no issues with the W9970, my daughter has a number of BT Mini Hotspot 600 units in use with that router.
Which BT connectors are you thinking about?
Message 4 of 4
The BT 600 series, and possibly a few of the other BT ones, may need a small config change.
See Problems on other routers using the BT hotspot 600
This is more of a problem if multiple hotspot units are added.
My daughter has four remote hotspot units running off a single master unit, to give wifi and Ethernet in each room.
