Message 1 of 6
TP-Link TD-W9980 QoS?
Hi,
I've just got myself a TP-Link TD-W9980 and have it up and running, but, I'm unable to enable QoS which is one of the main reasons I picked this router up. On the TP-Link site it says to go to the 'Advanced Setup' section to set up QoS but I don't seem to have the 'Advanced Setup' tab, only 'Quick Setup'.
I've just updated to the latest firmware to see if that added the appropriate settings, but still see no 'Advanced Setup' tab.
Does anyone have any advice?
Cheers!
5 REPLIES 5
Message 2 of 6
Re: TP-Link TD-W9980 QoS?
Bandwidth control tab on the left hand side menu.
Message 3 of 6
Oh OK, thanks!
So the higher the priority of the device means the higher the prioroty of the traffic to and from that device?
Message 4 of 6
When you add a device (by IP address) you can allocate up and down bandwidth to that device.
Tick enable bandwidth control and click save first. Then add devices.
Message 5 of 6
Message 6 of 6
OK, Thanks again for the help licquorice.
