My BT Home Hub router "experancing wifi problems" so I picked up an inexpensive TP-Link one to replace it. Infity requires a PPPoE enabled router and that is supported.
So with the VDSL modem linked to the BTHomeHub everything works but swapping in the new router it is failing to properly connect to the internet propper. My wired desktop is reporting the connection is "limited" My phone connecting over Wifi gets to an odd BT landing page with a wall of text that is of little use.
So to clarify the existing BT VDSL modem is connected to my phone line and has not been touched. I'm just swapping the router.
This is what I could find on the subject from BT LINK I have followed these instructions as best I can.
If anyone could shed some light and help me out that would be great.
Solved! Go to Solution.
Does it have a WAN port to connect your modem?
Eventually had found spec so are you connecting to wan
I simplay shut everything down, unplugged the red network cable from the HomeHub and plugged into the WAN port of the TP-Link router. Went to the router settings, it detected the type of connection (PPPoE) entered the user name and none password from the BT site. Restarted everything and the router "thinks" it has a good connection but any device connected through it can't get onto the net. Could it be a dns issue? have I missed something?
I assume that you have the white Openreach modem?
The instructions on that BT page refer to an ADSL modem, not a wireless router.
From my website.
Infinity uses PPPoE. (Point To Point Protocol Over Ethernet)
If you use a different router with Infinity, then you need to make sure that the authentication is set to PPPoE.
You can use a user name of broadbanduser@btbroadband.com and a password of btMTU Size: no 1492
Thanks for your reply, as prevousely stated in my posts I have done most these things. I will have the check out the MTU size settings and get back to you.
Make sure that the network settings are configured to get the DNS servers automatically from BT.
There should be a status page on the router to say what the current broadband IP address and DNS setting are.
Here is a dump of screen shots and log files...
Screenshots http://imgur.com/a/DPzwT
As you can imagine each time I try something and come back to the forum I'm having to swap the router each time. Sometimes answers are unread and I'm responding to the one before....
You primary and secondary DNS are set to OpenDNS, not BT, which is why you are seeing that strange text message.
Its telling you that you are trying to connect to a DNS server which does not belong to BT.
You will need to change the entries on both
You cannot use other DNS servers unless both BT Protect, and BT parental controls are fully uninstalled.
Remove the two optional DNS server addresses, and you will then get BTs own DNS servers.
If that does not work, then use a couple of these.
194.72.9.34 194.72.9.38
194.74.65.68 194.74.65.69
194.72.0.98 194.72.0.114
62.6.40.162 62.6.40.178
