ChrisDick052
Message 1 of 6
TP-Link modem to extend BT Hub wifi range
My kids cabin is too far from house for wifi. I have cable going to an old TP-Link TD-W8960N ADSL2+ wireless router which acts fine as a switch for a PlayStation and PC.
Can I use the TP modem's wireless to extend wifi on the same channel as the BT hub?
5 REPLIES 5
licquorice
Message 2 of 6
Re: TP-Link modem to extend BT Hub wifi range
You can but it would be better to use a different channel and SSID.
ChrisDick052
Message 3 of 6
Thanks for the reply. I have seen some posts about repeating the wifi to allow "seamless" roaming around the house but couldn't apply their answers to this TP modem. A different channel and SSID would require a log-in for each network??
Keith_Beddoe
Message 4 of 6
Seamless roaming is not possible without a mesh network like the BT Whole Home WiFi.
Devices will keep holding onto an existing connection until they do not see any signal at all.
licquorice
Message 5 of 6
Different channels won't make any difference to login. Once a device has connected to an SSID and the password entered, the credentials will be remembered for next time, so will be no different to having the same SSID. The benefit is that it will be possible to see which signal the device is connected to and manually change it if required. As Keith has said, seamless roaming between signals is only possible with true mesh systems, devices will drop and re-connect in exactly the same way regardless of having the same or different SSIDs.
ChrisDick052
Message 6 of 6
Thanks both for responses. I will set up the TP modem as a separate wifi network and a different channel, there are no other wifi's around so no problem there.
