Message 1 of 3
TP smart light bulbs and BT WiFi extenders.
Pretty much says it.
ive updated the WiFi extenders to BT mini Hotspot 600.
as the TP extenders we’re beginning to fail unfortunately I asked if they would work with the TP smart bulbs and was reassured they should. The app doesn’t appear to work. Any ideas to see how they might work or do I have to shell out more cash for TP link WiFi extenders?
2 REPLIES 2
Message 2 of 3
Re: TP smart light bulbs and BT WiFi extenders.
Welcome to this user forum.
Did you clone the settings of the home hub? If you did, then that will be the problem.
The Mini hotspot 600 will work fine with the home hubs, but can give problems with other routers unless you alter their configuration.
There should be no need for any special extenders.
Message 3 of 3
Thanks no I didn’t clone .
I’ll mess around tomorrow thanks.
John.
