keithw44
Message 1 of 4
TWCU.exe
The window I'm working in becomes innactive.  When I open task manager, processess, it looks like TWCU.exe is causing this to happen.  What is it and can I safely remove it
3 REPLIES 3
Keith_Beddoe
Message 2 of 4
Re: TWCU.exe
If you have a TP-Link wireless adapter, this may help.
http://forum.tp-link.com/showthread.php?2203-TWCU.exe-changes-focus-on-programs-in-Win7
The recommendation is to use Windows to manage the connection, and not the TP-Link utility.
I had similar issues, and now simply use the driver files, and not their wireless utility.
If you uninstall all of the software and drivers, then when Windows detects the adapter and asks for the drivers, simply insert the CD ans let it find the drivers, but do not install anything else from the CD.
If you get problems, then let me know.
keithw44
Message 3 of 4
Re: TWCU.exe
Thanks for the reply.
I'd forgot to mention that this problem only started when I got wireless internet with a link adapter.
When I get home I'll try what you said and let you know the outcome.
Many thanks
Keith_Beddoe
Message 4 of 4
Re: TWCU.exe
Many thanks
That would seem the problem. The page link I gave you does explain how you can disable the utility program without uninstalling anything.
