Message 21 of 30
Re: TalkTalk Homesafe blocking websites on BT broadband
Ideally I want compensation for the 3hrs approximately I've spent on the phone arguing and constantly explaining to people reading scripts on the other end that the problem isn't at my end of the line. I got pretty sick of endlessly hearing "We're providing you with broadband, so we're not the problem".
Message 22 of 30
You won`t get that I`m afraid. Here are BTs arrangements for Residential Customers.
Customer service guarantee
You should be able to work it out from that.
Message 23 of 30
Just an update guys.
I just had a surprise visit from some BT engineers to fix the phone line issue that was detected by the automated service I mentioned about. Before they even started to look for the problem, I mentioned the possibility of the switched connections, they went to check the exchange and found the error. It seems someone had mixed them up.
Many thanks for your help.
Message 24 of 30
I thought it had to be something simple. It may be worth logging into MyBT, and checking your recent usage since the fault was reported.
Do you still need the assistance of the moderation team?
Message 25 of 30
No, everything is working perfectly now thanks.
Message 26 of 30
I will let them know. Thanks.
Newbie
Message 27 of 30
Hi, I have the same problem, BT Broadband customer but just started getting the Talk Talk Homesafe message when I try to access various sites ...I am tech savvy, but no idea how to proceed ....can you help ?
Message 28 of 30
Hi,
Firstly, you'll find it's near enough impossible explaining the situation down the phone because it's so peculiar and completely off their script. The only way I managed to get it fixed was getting an engineer out and explain the situation to him.
It turned out that connections within my block of apartments accidentally got switched at the connection box. I had someone elses broadband, and they had mine.
If I remember rightly, if you test your phone line on the BT website it should pick up on some problems saying that they need to send someone out to check the lines. Calling the customer services for broadband will just result in them checking your connectivity, saying it's fine and that the problem is with your devices and then closing the ticket.
I hope this helps in some way. No one should go through the headache it caused me.
Newbie
Message 29 of 30
Seems to be sorted now, BT must have picked up on it ...thanks for the advice ! Cheers
Moderator
Moderator
Message 30 of 30
Moved:
