roobytubey
Message 1 of 2
Telephone Pole Fault
There is a fault on the telegraph pole serving houses in Southgate Gardens, Stroud. This is clearly a pole problem as it affects other houses connected to it - leaving homes without Telephone or Internet since Tuesday.
BT have confirmed a line fault but a fault at the pole seems almost positive to be the problem.
Is there any updates on this problem?
Thanks.
1 REPLY 1
Message 2 of 2
Re: Telephone Pole Fault
This is purely a customer forum, messages do not go to BT.
If you login to your bt.com and look at faults, you should see your report, and any updates.
