abathingape
Message 1 of 22
Telnet/SSH to Openreach HG612 Modem Not Working
Afternoon,
I have unlocked HG612 modem with the Web GUI installed.  However I'm not able to connect via Telnet/SSH for whatever reason?  Does it have to be enabled anywhere?  I can ping the modem, and access the Web GUI with no issues at all. I have noticed that the Firewall setting is set to 'standard'.  Does this need to be set to 'Disabled' for it to work?
My setup is:
Asus RT-AC68U Router --> HG612 Modem --> Phoneline.
21 REPLIES 21
Liam_
Recognised Expert
Message 2 of 22
Re: Telnet/SSH to Openreach HG612 Modem Not Working
Have you tried connecting directly to the modem, as in bypassing the router?   I don't use an OR modem but to access the DrayTek it needs a direct connection.
licquorice
Message 3 of 22
Telnet access is still admin/admin even if you have changed it in the webgui
abathingape
Message 4 of 22
I haven't tried accessing it directly.
abathingape
Message 5 of 22
I don't even get as far as being prompted for credentials.
licquorice
Message 6 of 22
What address are you attempting to access, it will be 192.168.1.1
licquorice
Message 7 of 22
Connect LAN port2 to a LAN port on your router.
abathingape
Message 8 of 22
Well I changed the address of my modem so that it tied in with the rest of my network, so I access my webgui using 192.168.0.2...and that is the address I am trying.
abathingape
Message 9 of 22
LAN Port is connected to router as I can access the webgui perfectly fine. What should the firewall setting be on the modem?
licquorice
Message 10 of 22
Didn't change mine from default, in France at the moment so can't check actual settings.  I can telnet fine using Putty without changing any settings on the modem.
