Message 11 of 15
Re: Terrible Latency
My guess is that your exchange is overloaded.
Have you checked here http://usertools.plus.net/exchanges/
Eagle0505
Message 12 of 15
Yep no known capacity issues on my exchange 😞
20:14 Test (back to good again but has been at 300+ most of the afternoon):
Pinging www.bbc.net.uk [212.58.244.66] with 32 bytes of data:
Reply from 212.58.244.66: bytes=32 time=42ms TTL=50
Reply from 212.58.244.66: bytes=32 time=34ms TTL=50
Reply from 212.58.244.66: bytes=32 time=33ms TTL=50
Reply from 212.58.244.66: bytes=32 time=37ms TTL=50
Ping statistics for 212.58.244.66:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 33ms, Maximum = 42ms, Average = 36ms
Message 13 of 15
may have been a network issue slowing things down a little
just keep n eye on the ping times and post back if things get worse
Eagle0505
Message 14 of 15
Pinging www.bbc.net.uk [212.58.246.93] with 32 bytes of data:
Reply from 212.58.246.93: bytes=32 time=339ms TTL=51
Reply from 212.58.246.93: bytes=32 time=199ms TTL=51
Reply from 212.58.246.93: bytes=32 time=174ms TTL=51
Reply from 212.58.246.93: bytes=32 time=282ms TTL=51
Ping statistics for 212.58.246.93:
    Minimum = 174ms, Maximum = 339ms, Average = 248ms
Trying to play online games is unbearable...... it takes a distinct amount of time to respond to input now and its every evening! I hoped by switching recently things might improve but apparently not 😞
Eagle0505
Message 15 of 15
I also have some friends of mine that are coming to post about similar issues that all have BT lines. I think this may be a wider spread problem.
