Eagle0505
Message 1 of 15
Terrible Latency
Hi there,
We switched to BT a couple of months ago and originally things were great, after a week our HH3 died and we had to get it replaced. Now a month later from that we are now getting shockingly back latency from our service.
While the speed is good the latency is awful, I am working on a wired connection so please do not refer to wireless.
Here are the ping results:
Pinging www.bbc.net.uk [212.58.244.67] with 32 bytes of data:
Reply from 212.58.244.67: bytes=32 time=883ms TTL=50
Reply from 212.58.244.67: bytes=32 time=893ms TTL=50
Reply from 212.58.244.67: bytes=32 time=921ms TTL=50
Reply from 212.58.244.67: bytes=32 time=917ms TTL=50
Ping statistics for 212.58.244.67:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 883ms, Maximum = 921ms, Average = 903ms
Any help will be appreciated.
Tags (2)
14 REPLIES 14
Message 2 of 15
Re: Terrible Latency
Welcome to this customer to customer forum.
To enable forum members to help you, could you please read the web page that is shown below, which asks you to do a few checks first, and has some helpful hints.
And yes, connection problems can cause latency problems.
When you have done that, please follow the instructions at the end, and post the results here, so members can offer advice. Thank you.
Speed and disconnections
Eagle0505
Message 3 of 15
ADSL Line Status
Connection information
Line state:Connected
Connection time:1 day, 21:23:54
Downstream:3,776 Kbps
Upstream:448 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):9.0 dB / 23.0 dB
Line attenuation (Down/Up):50.0 dB / 30.5 dB
Output power (Down/Up):18.6 dBm / 12.2 dBm
FEC Events (Down/Up):50505 / 11
CRC Events (Down/Up):668 / 6
Eagle0505
Message 4 of 15
Sorry for the small image
Speedtest
Message 5 of 15
You should be connecting at about 4832kbs so there must be something affecting your speed.
There are some errors which will affect latency to some extent.
Which type of master socket do you have?
One of these
Or one of these
Or if you are lucky
One of these
Eagle0505
Message 6 of 15
I have one of the ones at the bottom (the lucky ones) but we had trouble with it a while ago so now just have our HH3 connected directly through the test socket using the ADSL filter.
Message 7 of 15
Have you another router you can try?
Does restarting the home hub make any difference?
Eagle0505
Message 8 of 15
I have a D-Link one as well but i've just ran another ping test and its all ok again. I'll try again tonight to see if its a time of night thing as during the week i've had issues but that always tends to be in the evenings.
Message 9 of 15
Try some tests at different times of the day, it would be interesting to see the results.
Eagle0505
Message 10 of 15
17:20 - 25th Feb 2012
Pinging www.bbc.net.uk [212.58.246.90] with 32 bytes of data:
Reply from 212.58.246.90: bytes=32 time=278ms TTL=51
Reply from 212.58.246.90: bytes=32 time=539ms TTL=51
Reply from 212.58.246.90: bytes=32 time=305ms TTL=51
Reply from 212.58.246.90: bytes=32 time=312ms TTL=51
Ping statistics for 212.58.246.90:
    Minimum = 278ms, Maximum = 539ms, Average = 358ms
Earlier it was showing 37ms when I made the last post
