Message 1 of 2
Terrible wifi, terrible service
Our BT wifi has never worked properly - for years it has dropped out - doesn't reach most of the house and then when our Sky system started using WIFI the TV often didn't work. Engineers have come out many times and recently we were given a new modem which has fixed the TV problem but now the actual wifi drops out all the time. Our son has moved out because he can't play his computer games anymore, frequently important zoom calls for work are interrupted and I have to use 4G most of the time. Every time I try to cancel our service and move to another company I am passed from pillar to post and told I can only leave if I pay £350 cancellation fee and if I don't pay it the debt collectors will come round. So as a consumer I have no rights. Why should I pay for a service that doesn't work and why should I be penalized for simply wanting WiFi? Any suggestions as to what to do would be most gratefully received.
1 REPLY 1
Message 2 of 2
Re: Terrible wifi, terrible service
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Have you tried selecting the channels manually instead of auto?  I would use a wifi analyser on your phone and see what channels are in use and select a free or less congested channel  I would also ensure you don't use channel 36 for 5ghz as that is used by SKYQ
have you turned of smart setup
https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off-
Someone may then be able to offer help/assistance/suggestions to your problem
