Innggi
Message 11 of 15
Re: Texecom Speech Dialler reducing speed of Infinity2
Tx Ray.
By adding extra filters, is that part of the socket, do I need to buy a particular type of product, can you recommend a product.
I will try the filtered terminals option first.
ray_dorset
Distinguished Guru
Message 12 of 15
I meant these
If not, I'll try again 🙂
Tags (1)
Innggi
Message 13 of 15
Aha! I c.
Innggi
Message 14 of 15
Hi Ray
Your suggestion worked. The engineer had not come across the Master Sockets used with Infinity2. He had connected to the unfiltered terminals. The Speech dialler is connected to the filtered terminal, it is working fine and the Broadband speed is reading circa 76MB download.
Thank you very much for your assistance.
kind regards
Ghafoor
ray_dorset
Distinguished Guru
Message 15 of 15
Excellent news 🙂
