geordiechris
Message 1 of 7
Text Messaging
Can't send texts at the moment, anybody else experiencing this? Can call and have data access no problem.
6 REPLIES 6
geordiechris
Message 2 of 7
Re: Text Messaging
Problem seems to be fixed now. All is good
Devon_Dave
Distinguished Guru
Message 3 of 7
Re: Text Messaging
have you ever been able to send texts?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
geordiechris
Message 4 of 7
Re: Text Messaging
Yes had contract a while now and only today experienced a problem
Seamaster
Message 5 of 7
Re: Text Messaging
I can't send or receive texts either. iMessage (over wifi) fine.
Checked on Twitter, EE are having data and text problems across the network.
mike-l
Message 6 of 7
Re: Text Messaging
I have been unable to send or receive  texts reliably for ages (weeks). How was the problem resolved, what is the detail? Should I call the help desk? I did try that a number of times but maybe you have hit on the magic bullet that they were unable to find. Please let us knoe the low-down.
Seamaster
Message 7 of 7
Re: Text Messaging
Came back to life for me shortly after posting the above. EE network problems. You may be in a cell area that is still affected.
