Message 11 of 17
Re: Text messages come through as voice mails
Thanks Dave - it's 5 0's (00000), that worked for me!
Recognised Expert
Message 12 of 17
Didn't work for me.
I have registered
I have caller display even though 00000 says I don't.
Still receiving Texts as voice texts!!  I think I will give up unless anyone has any suggestions.   It is a recently aquired new BT phone.  P.
Edit.. Sorry I didn't realise this was a previously  Solved post.
Message 13 of 17
This should help http://www.bt.com/includingyou/calling-easier-unwanted-calls.html#more3
Select Turn off receiving ALL messages
Recognised Expert
Message 14 of 17
Thanks Keith
  But they are not unwanted texts they are genuine so I would like to receive them....but not as voice texts.
Message 15 of 17
@Patty-L wrote:
Thanks Keith
I wonder if you turned them off, wait a while, then turn them on again, it may update the settings?
Recognised Expert
Message 16 of 17
I will try that now and post back with the result later.
It is a text enabled phone. BT 7600
Edit
I'm a little wary of that Keith after looking at instructions,  in case I cannot turn it back on.
Message 17 of 17
@Patty-L wrote:
Didn't work for me.
I have registered
I have the same problem with a new BT 8500 phone.
I have managed to get a couple Text messages as text but it keeps reverting to Voicemail even immediately after I try and register to 00000 (done many times).
I have not found any way to report the fault online, using the online phone fault reporting page just tests the line, says it is OK and do I want to pay for an engineer to visit!  No way entering details of the BT Text fault.
I rang 0800 and spoke to someone who said they get someone else to call me back and tell me what to do, they never did and I have a suspicion they will just tell me to register to 00000!
I have been using a Panasonic DECT phone on the same line to send and receive Text messages for years.
MB
