Message 1 of 3
Thank you BT
BT
Thank you for the excellent and straight forward install. I now have internet access that is usable (except for the port forwarding issue). I was with Virgin BB 30mb service however every evening and all day sunday it was unusable with high latency and dropped packets.
for instance,  ping to google via BT
Pinging google.com [209.85.147.105] with 32 bytes of
Request timed out.
Reply from 209.85.147.105: bytes=32 time=17ms TTL=49
Reply from 209.85.147.105: bytes=32 time=16ms TTL=49
Reply from 209.85.147.105: bytes=32 time=18ms TTL=49
Pings to google via Virgin
Reply from 82.44.243.24: bytes=32 time=34ms TTL=51
Request timed out.
Reply from 82.44.243.24: bytes=32 time=239ms TTL=51
Reply from 82.44.243.24: bytes=32 time=39ms TTL=51
Reply from 82.44.243.24: bytes=32 time=33ms TTL=51
Reply from 82.44.243.24: bytes=32 time=113ms TTL=51
Request timed out.
Reply from 82.44.243.24: bytes=32 time=59ms TTL=51
Reply from 82.44.243.24: bytes=32 time=128ms TTL=51
Reply from 82.44.243.24: bytes=32 time=15ms TTL=51
Reply from 82.44.243.24: bytes=32 time=159ms TTL=51
Request timed out.
Reply from 82.44.243.24: bytes=32 time=104ms TTL=51
Request timed out.
Request timed out.
Request timed out.
Reply from 82.44.243.24: bytes=32 time=187ms TTL=51
Reply from 82.44.243.24: bytes=32 time=36ms TTL=51
Request timed out.
Reply from 82.44.243.24: bytes=32 time=153ms TTL=51
Reply from 82.44.243.24: bytes=32 time=75ms TTL=51
Request timed out.
Request timed out.
Reply from 82.44.243.24: bytes=32 time=14ms TTL=51
Reply from 82.44.243.24: bytes=32 time=133ms TTL=51
Reply from 82.44.243.24: bytes=32 time=28ms TTL=51
Request timed out.
Request timed out.
Reply from 82.44.243.24: bytes=32 time=99ms TTL=51
Reply from 82.44.243.24: bytes=32 time=88ms TTL=51
Request timed out.
Reply from 82.44.243.24: bytes=32 time=48ms TTL=51
Reply from 82.44.243.24: bytes=32 time=54ms TTL=51
Reply from 82.44.243.24: bytes=32 time=118ms TTL=51
Reply from 82.44.243.24: bytes=32 time=58ms TTL=51
Request timed out.
Request timed out.
Reply from 82.44.243.24: bytes=32 time=32ms TTL=51
Reply from 82.44.243.24: bytes=32 time=53ms TTL=51
Reply from 82.44.243.24: bytes=32 time=25ms TTL=51
anyways as with reporting problems, i like to also praise good service.
Merry Christmas all
Dean.
2 REPLIES 2
Message 2 of 3
Re: Thank you BT
glad to hear other users have had a good experience
Message 3 of 3
Re: Thank you BT
yes me too, well done BT
