My BT YV+ box had another maintenance mode menu. Normally I've chose first option, software reset, and it just then restarts and all my recordings and scheduled are there.
Today another one, did the same, booted up, this time seemed to do a tune for channels, came on and wow everything is deleted on "My TV" and no scheduled.... Great thanks a lot. Now what...?...
Is there any way to get the recordings back or am I now snookered?
From your earlier thread
https://community.bt.com/t5/YouView-Boxes/Replacement-BT-Ultra-box/m-p/1769091
i assume this box box is the original one that you are attempting to watch old recordings off rather that the new replacement that BT provided.
If your recordings are not listed then sadly they are not available. you could I guess try another maintenance mode reset option 4 to see if after that they reappear but I would not hold out much hope.
No haven't plugged in new one yet as was hoping to watch all recorded programme first....
I'll try the 4th option down but don't hold much hope. Is the first option (software reset (recommended), is this supposed to keep the recordings?
Which is the newest remote out of interest. My original has a blue you view button, the new box has a blue house picture.
It was a a very long shot ...
as for remote I would guess the one with the house is the latest as that is the one described in the user guide for the next gen (new look) Youview interface. Use the one that you feel most comfortable with.
the house symbol is I guess is to signify the home location .. same effect as the Youview button
Look on the bright side, you now have loads of free space on your disk !
I've done a 'reset keep recordings' on my UHD box 2 or 3 times now and not lost recordings. I thought I'd pressed the wrong option last time I did it so a few anxious moments !
