ojobson
Message 1 of 10
That 'When' Question - Fibre going in the ground right now...
We've been waiting ages and something is happening!
OpenReach engineers are working outside my house right now laying fbre for FTTP (I asked them).
But:
Openreach checker still says 'Exploring Solutions'.
SamKnows only reports that exchange is FTTC enabled.
Our cabinet has not been upgraded.
We live on a new housing estate.
Wondering from the experience of others how long it might take to go from Fibre going in the ground to a live connection to the house.
Yes, it might be 'how long is a piece of string' but interested in the experience of others.
Thanks,
___________________________________
My Blog: oliverjobson.co.uk | My FTTP install experience | Why can't I order Fibre broadband?
9 REPLIES 9
Webby
Message 2 of 10
Re: That 'When' Question - Fibre going in the ground right now...
There is no time frame.
Every single area and installation is different and will take as long as it takes.
You only know it’s ready once you can order it.
pippincp
Sage
Message 3 of 10
There's no such thing as an FTTC enabled exchange.
Webby
Message 4 of 10
Splitting hairs...
ojobson
Message 5 of 10
Pippincp - I didn’t say there was, my post states that SamKnows reports the exchange to be only FTTC enabled (there is a red x next to ‘FTTP enabled’ under the BT Wholesale section).
That aside, care to provide a more constructive comment about this apparently misleading information?
pippincp
Sage
Message 6 of 10
Once an exchange is fibre enabled it can supply both FTTC and FTTP services. The red x next to FTTP simply means that it can not be ordered.
SamKnows only states what is available to order in the some of exchange area.
THIS checker is more informative than SamKnows.
ojobson
Message 7 of 10
Thank you - that’s really useful. Good to know that no further work needs to be done at the exchange.
Webby
Message 8 of 10
I think the x means there’s just not FTTP areas currently live on the exchange (which is the same as meaning it can’t be orderd) however I would imaging FTTPoD is...
ojobson
Message 9 of 10
I learned something else - the cabinet isn't used for FTTP. The house fibre connections is to the street fibre which runs to the exchange. So the cabinet not being updraded isn't an issue. One less obstacle to be overcome.
gazm1990
Message 10 of 10
I wouldn't believe what SamKnows says when it comes to FTTP. I've had FTTP at my house for over a year and SamKnows reckons the best I can get is ADSL! It would appear that when it comes to FTTP, SamKnows very little...
