BT Sport is streamed via the internet, although you can record on the Youview box as you would any Freeview broadcast. You would need to be on Infinity or a reasonably fast (5.25mbps or above) ADSL line, which has to be multicast enabled, to receive it.
Why not use powerline adapters to make an ethernet connection from your router to the BT TV box? Problem solved.
Someone Solved Your Question? ![]() Please let other members know by clicking on ’Mark as Accepted Solution’ | Helpful Post? If a post has been helpful, say thanks by clicking the ratings star. |
