Kingside
Message 1 of 3
Thunderbird SSL/TLS
I have finally managed to set up Thunderbird manually with my new btinternet email account - but had a lot of trouble in spite of all helpful forum advice.
 I found the problem to be the SSL/TLS feature. If I set it (as recommended in the BT advice ) on then I cannot get a connection.
I get the message "Thunderbird could not connect. The connection was refused ."
But if I set security to None the connection works fine.
Does this matter ? I can't tell if I am exposed by having the setting at none . And is there anything I can do about it?
2 REPLIES 2
miles_safer
Expert
Message 2 of 3
Re: Thunderbird SSL/TLS
I too had issues setting up Thunderbird, first with O2 & now with BT having been with O2 for 4 years with the SSL/TLS set to off I have not experienced any problems. So I have not been worried to set the security to off to get BT email to work on Thunderbird.
Message 3 of 3
I managed to set up TB with IMAP in an earlier thread on my pc and HTC desire, the search device will take you to the settings.
AQ.
"Welcome to Royston Vasey - You'll never leave."
