Distinguished Guru
Message 11 of 22
Re: Told I would need an engineer
You're assuming that the results of BT's fault tracker bear any semblance to reality.  In practice, the only way to find out where the fault really is is to send somebody out to trace where the problem lies.
Message 12 of 22
John thanks for your help I have done what you suggested and my speeds have increased, I have returned the ste up to how it was originally and the speeds are still faster than before, very strange. i will keep a check on it over the weekend to see what happens. Just a shame India did not get me to do this on Monday.
Distinguished Guru
Message 13 of 22
There's a BT video here http://www.youtube.com/watch?v=NGtz-GCi7yw
If not, I'll try again 🙂
Message 14 of 22
Thanks I have tried the master socket and speed went up to 30mb, I have now reverted the set back to how it was before and I am still getting 30mb surely if it was an internal problem the speed would of dropped back to the 12mb I was getting
still a long way from the 70mb I used to get but perhaps DLM will kick in I will monitor over the nest week and see what happens.
Message 15 of 22
"You're assuming that the results of BT's fault tracker bear any semblance to reality. In practice, the only way to find out where the fault really is is to send somebody out to trace where the problem lies"
Seems to be a bit pointless having a fault tracker then,
Distinguished Guru
Message 16 of 22
What's your noise margin like, that's the important bit ?
Message 17 of 22
Dont think an HH3 gives those stats. perhaps if and when I renew my contract I can ask for an HH5
Distinguished Guru
Message 18 of 22
Which modem do you have - ECI or Huawei?
Message 19 of 22
I have an ECI modem .
Message 20 of 22
the fault tracker if fairly basic the only real test is an engineer visit it sounds like you may have a faulty master socket making an intermittent contact
