Message 1 of 4
Total entertaiment package
Good afternoon, l am thinking of getting the tv package, but l have a query that l hope you can help me with, l am thinking of getting the total entertainment package, but l do not  have an ultra tv, will it work on a normal hd television, and then upgrade my tv later
3 REPLIES 3
Distinguished Guru
Message 2 of 4
Re: Total entertaiment package
Hi @Gordon2u,
You can still order the service, providing your speeds are up to it.
Of course, you will only be able to view any UHD content in HD until you change your TV.
See BT Ultra HD - TV compatibility and HDMI port settings for a list of compatible UHD TV's.
DanielS
Message 3 of 4
Thanks when l went through the ordering it would let me order it, so running infinity 2, just did not want to waste money on a normal box then having to update thanks for your help
Distinguished Guru
Message 4 of 4
You are very welcome @Gordon2u.
Personally, I have the Total Entertainment package with Second Box. It's all working on my HDTV fine.
Enjoy your day Smiley Very Happy
DanielS
