Message 1 of 3
Transfering music from PC to PS3 over a wireless connection. Usage limit affected?
Hi there
I would like to know if/when I copy all of my music (abouit 10gb) and photos (about the same amount) from my PC to my PS3 over a wireless connection, will it use of any of my 10gb download limit?
This would be the easiest option for me, but I don't want to go over my limit......I've had 2 different responses from BT when I called them (about different things) so am still none the wiser.
Does anyone have a definate answer please?
Tags (4)
2 REPLIES 2
Message 2 of 3
Re: Transfering music from PC to PS3 over a wireless connection. Usage limit affected?
@Yellsie wrote:
Hi there
No, not if they are both on the same network, you will not use any of your broadband connection.
Distinguished Guru
Message 3 of 3
Hi Keith is correct, it does NOT count against you.
I do it all the time with music and video files. So rest easySmiley Happy
toekneem
(EASBF)
