Jamesstevens
Message 1 of 6
Trial FTTC Unlimited Faster Broadband or possibility of FTTP
Im currently on ADSL 2+ and Im receiving the max speed estimate of 5.5mb BT suggest for my line. I want to know if I could trial Unlimited Faster Broadband as currently BT dont give me the option because of distance of 3km but the FTTC cabinet is 500m closer than the exchange and my line seems to have a great speed considering the distance. Also I would go for FTTP if it was available especially as for laying the fibre there is already copper and fibre running from the local exchange straight passed my house so would be a simple case of threading a line through or connecting into the existing fibre.
5 REPLIES 5
imjolly
Message 2 of 6
Re: Trial FTTC Unlimited Faster Broadband or possibility of FTTP
enter your phone number and post results  remember to delete number  https://www.btwholesale.com/includes/adsl/main.html
Webby
Message 3 of 6
At 2.5km from the cabinet you're unlikely to get anything on VDSL2, if you did I doubt it would be as good as 5.5meg.
BT won't offer it as a trial.
Can you pop your number into here http://www.dslchecker.bt.com and post the results. Remove your number before posting.
licquorice
Message 4 of 6
You can't compare the speed of ADSL 2+ and FTTC.  VDSL speed drops off much quicker over distance than ADSL 2+
licquorice
Message 5 of 6
This quite an old graph and is a bit pessimistic with regard to VDSL speeds but you can see that ADSL2+ is quicker over relatively short distances and continues to be as distance increases.
FTTN VDSL2 speed graph
john46
Message 6 of 6
"Also I would go for FTTP if it was available especially as for laying the fibre there is already copper !and fibre running from the local exchange straight passed my house so would be a simple case of threading a line through or connecting into the existing fibre." it is not as simple as that I am afraid ! there is a lot of infrastructure work needed
