JayZS
Newbie
Message 1 of 4
Trojan Detected
My Netprotectplus McAfee scan says "0 viruses ans spyware detected in your last scan".   Fair eough.  But when I view the scan report it says that  1 trojan was detected.
Whuch is correct?   How do I know whethert the trojan has been deleted?  Is it possible to see a file that shows where the trojan was/is in my system?
It does not say trojan removed, unless, maybe,  there is a more detailed log file that I can look at?
3 REPLIES 3
Distinguished Guru
Message 2 of 4
Re: Trojan Detected
Hi JayZS and welcome
It appears to be reporting that it has found a trojan, but doesn't mean it was found during the last scan.
From the home page click Navigation (top right), then click on Quarantined and Trusted Items, then check Quarantined Items and/or Quarantined Potentially Unwanted Programs.
From there, you should be able to Select the trojan, then remove/delete it...
(You could also dump the 207Cookie that's bound to be there!!Smiley Wink).
-+-No longer a forum member-+-
dave01
Newbie
Message 3 of 4
Re: Trojan Detected
I seem to have encountered the same problem, Thanks for the tip on how to remove but I cannot find the navigation tab to get started..can you help please
Tags (2)
Distinguished Guru
Message 4 of 4
Re: Trojan Detected
Hi dave01 and welcome
Simply look for the shield - BTNP.JPG - and double left click to open BTNP
You'll find the navigation button on the window that opens (upper right)
