racey
Message 1 of 13
Trojan detected but will not repair
McAfee has detected a trojan but clicking  "repair" does not remove the file.
Help please.
12 REPLIES 12
CMD104
Message 2 of 13
Re: Trojan detected but will not repair
what is the trojan? can you quarantine it?
hamish72
Recognised Expert
Message 3 of 13
Run Windows in SAFE mode and try again
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
Ryanm353
Message 4 of 13
Scrap McAfee, its **bleep**!!
Use microsoft security essentials or avg free and also download malwarebytes anti-malware and do a scan and it will speed things up and also clean it up! 🙂
racey
Message 5 of 13
The trojan is
susp irp mj create.
I can't highlight it to quarantine or repair it.
racey
Message 6 of 13
Trojan susp irp mj create
I've run Malwarebytes but it does not pick it up.
racey
Message 7 of 13
there are now 2 files called susp irp mj create and another called Image Path.
I can't repair or quarantine them.
Help!!
RubberNutter
Message 8 of 13
Hi
since it gives you the name of the trojan try and do a search for and manually delete file. Try the link below it is a stand alone checker from Kaspersky the best home virus software available. All you do is run it and clean, it will remove itsslf once finished and then reboot, hopefully this will help.
http://support.kaspersky.com/viruses/avptool2010?level=2
hamish72
Recognised Expert
Message 9 of 13
Did you try in safe mode yet many anti virus succeed in safe mode with things they cant remove normally
racey
Message 10 of 13
The files have mysteriously disappeared.
Is Kapersrsky better than McAfee? If so I might try it as it's provided free by Barclays Bank.
