ChrisAnn
Message 1 of 6
Trojan found - has it been made safe?
McAfee has just 'done' its weekly full scan of my computer. The security report says it detected 1 trojan. It also says that my system is secure and no action required.
This may be an obvious question - but is there anything I should do to remove the found Trojan? If so I can't find a way to remove it. Or, which I hope is the case, has McAfee dealt with it and I have nothing further to worry about?
I always look at the security report and this is the first time it has indicated that something has been found.
5 REPLIES 5
Message 2 of 6
Re: Trojan found - has it been made safe?
there is nothing to do as McAfee will have either deleted or put in quarantine.  probably came with something you downloaded
WellGrumpy
Message 3 of 6
Most security systems block Trojans. To be sure download and run Malwarebytes that shuold kill off any Tojans.
themidlander
Message 4 of 6
This is a good programme for you
        superantispyware
ChrisAnn
Message 5 of 6
Thanks for reassuring me. I'll have a look at the two programs recommended although I do have Ad-Aware installed which I think does the same thing.
Hazeno
Message 6 of 6
http://forums.majorgeeks.com/showthread.php?t=35407
Always the best removal guide for any Trojans and Malware. Run that any problems hit up the community forums with your logs. Those guys in there are beyond intelligent.
On a side note , i prefer ESET Nod32 as my AV if i ever actually use any.
