Message 11 of 19
Re: Troubles gettining into some services webpages since yesterday?
Also incase it matters, i just managed to do the freeola line quality test and it comes back as 100% packet loss, thats not good is it?
Message 12 of 19
Do you just have the HH5, or do you have the white Openreach modem as well?
Message 13 of 19
No just the home hub 5 my old open reach died some time ago
Message 14 of 19
Can you please display all the information as described here, so we can see the connection status, as you could have a line problem.
Check your connection speed for the Home Hub 5
Message 15 of 19
1. Product Name: HomeHub5 2. Serial number: +076284+1443002507 3. Firmware version: v0.07.01.0235-BT (Type B) Last updated [Unknown] 4. Board version: 01 5. VDSL uptime: 0 days, 00:08:27 6. Data Rate: 20000 / 60649 7. Maximum Data Rate: 22363 / 72341 8. Noise Margin: 6.4 / 6.3 9. Line Attenuation: 0.0 / 14.3 10. Signal Attenuation: 0.0 / 0.0 11. Data sent/received: 1.2 MB / 6.5 MB 12. Broadband username: bthomehub@btbroadband.com 13. BT Wi-fi: No 14. 2.4GHz wireless network/SSID: BTHub5-P3Z8 15. 2.4GHz wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s)) 16. 2.4GHz wireless security: WPA2 Only (Recommended) 17. 2.4GHz wireless channel: Automatic (Smart Wireless) 18. 5GHz wireless network/SSID: BTHub5-P3Z8 19. 5GHz wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s)) 20. 5GHz wireless security: WPA2 Only (Recommended) 21. 5GHz wireless channel: Automatic (Smart Wireless) 22. Firewall: Default 23. MAC Address: 18:83:bf:eb:10:37 24. Software variant: - 25. Boot loader: 0.5.0-BT (Tue Jun 17 18:52:56 2014)
Message 16 of 19
Cannot see anything obvious there. Its a pity that the HH5 does not give error stats.
Can you hear any noise on your landline phone. Dial 17070 and select option 2.
To eliminate any issues with your wiring, can you connect things up as shown below, and see if things are any better.
Message 17 of 19
Yeah i tried that it didnt work, there's been a fault raised by someone in my area about the broadband, so it's not just me, apparently it was fixed at 11:50 though (it's still not working any better) phoned up BT they have logged it as a phone fault and not a broadband fault /facepalm, anything else i can do?
Message 18 of 19
Curiously, 99% of stuff, albeit a little slower then im used too are working now through Hotspot Shield, my normal VPN PIA still won't work though (note, i do not use a VPN all the time, just signed up to try and get somewhere with my Uni work.
Does this tell us anything!?
Message 19 of 19
Any one can help?
