d_b
Message 1 of 2
Troubleshooting
I have recently installed the BT Whole Home Wifi disks on my network.
Whenever I open the Android ap "BTWhole-Home" it always says
"There's a problem with your internet connection"
If i follow the Troubleshooting actions everything comes out OK.
I am running V1.02.01 build24 on the disks which are connected to a BT HH5
I can obviously cobbect to the internet so I do not understand what the app is complaining about -
If I follow the action that says reboot everything the app says everyting is good for about 30 seconds before it then complins.
Is the APP broken or do I have a real problem?
This bit might be a red herring - I have a Q2 internet radio which has always had issues - everynow and then it just stops and the lights flash to say it cant get to the internet - this is direct to the BT HH5 - it was for this reason I invested in the BT Whole Home system assuming I had poor coverage from the BT HH5.
1 REPLY 1
PaddyB
Moderator
Moderator
Message 2 of 2
Re: Troubleshooting
Hi @d_b,
Welcome to the community forum. I'm sorry you're experiencing issues with your BT Whole Home Wifi. You can contact the BT Whole Home Wifi helpdesk on 0808 100 6116 or an email to: btconnectedhome@bt.com and they'll be able to take a look at this for you.
PaddyB
