Emrsw01
Message 1 of 3
True Key import from Keepass
Hi hope someone can help.
Have just downloaded True Key and initial thoughts are it is ok.
However i have all my passwords stored in Keepass and would like to import them to True Key but there doesnt appear to be an option to do this.
Spoke to Mcafee on chat line and they were unable to help as i had the BT version so assured me that BT technical support for this product would be able to assist!
I assume this will be a complete waste of time and effort so has anyone had same issue and found a resolution?
Failing that i will uninstall it and keep using Keepass.
Also far to many passwords to do it manually.
2 REPLIES 2
NeilO
Moderator
Moderator
Message 2 of 3
Re: True Key import from Keepass
@Emrsw01 thanks for posting, I've found the following guide on the true key support webpage explaining how to import passwords. Can you give it a try and let me know if it helps?
Emrsw01
Message 3 of 3
Hi,
Thanks for your reply.
Unfortunately tried all options available but no possibility of importing from Keepass.
Keepass will allow export to a csv but no option to import from a raw csv file available in True Key.
Have now deleted True Key and sticking with KEEPASS which for a freeby is a good piece of software.
I have at least 100 diferent logins so would be very difficult to input all manually.
Thanks again for replying.
Bob
