Message 1 of 10
Trying to connect laptop using intel proset/wireless connection utiity
I have a work laptop that only uses the intel proset/wireless connection utiity to connect to wireless networks. (all other options are disabled by the administrator) When i try to connect to my home wireless network the intel utility runs the "wi-fi protected setup wizard" and generates a password "that identifies this device" it then generates a 8 digit number which it asks me to " enter the device password in the access point or external registrar"
Where do I do this?
The utility doesn't give me the possibility to enter the network password that I have used to succesfully connect all my other devices
I have a HomeHub 4.0 type A
9 REPLIES 9
Message 2 of 10
Re: Trying to connect laptop using intel proset/wireless connection utiity
It could be that your laptop is locked down by your employer to prevent it logging onto any networks other than your works one.
Have a look through these links to see if they help and if they don't you may need to contact your works IT manager to see if he can help.
http://www.intel.com/support/wireless/wlan/sb/CS-030415.htm
http://www.intel.com/support/wireless/wlan/sb/CS-031925.htm
Message 3 of 10
thanks for your prompt reply however my works laptop was able to connect to my previous netgear router and has connected to other wi-fi networks.
my works IT manager says that it is an issue with the BT router because of the higher security WPA-2 and I need to ring BT to ask them to enter the key that the intel proset wirlesss utility generates. Given how long BT takes to respond to a call for support is there any other way I can do this myself?
Message 4 of 10
Is WPS enabled on your hub?
Message 5 of 10
Yes it is
Message 6 of 10
What happens if you turn off WPS on your hub? The documentation suggests that the proset software would then instead ask for your password.
Message 7 of 10
thanks for the suggestion i will give it a try this evening
Message 8 of 10
you can also change the wireless encryption and wireless security code yourself
Message 9 of 10
Great that did the job, thanks 🙂
Message 10 of 10
Glad it helped you. Smiley Happy
