Message 1 of 6
Trying to log onto MyBT redirects to Webmail page
Trying to log onto MyBT redirects to Webmail page. Has anyone else had this problem?
5 REPLIES 5
Message 2 of 6
Re: Trying to log onto MyBT redirects to Webmail page
Are you selecting MyBT from this page?
https://www.bt.com/
Message 3 of 6
Just tried from there and still get redirected after briefly seeing a "myBT" page before redirecting to the webmail
Message 4 of 6
If this is a new problem and it used to work perfectly, try a different browser just to check another possibility.
Message 5 of 6
Hi, Have just had chance to check with different Browser & Laptop & OS ( problem under Chrome & Windows 10, OK with Firefox & Linux) will clear down Chrome "History" and mark as fixed. If not OK will open new problem.
Message 6 of 6
Having the same problem tried it with Edge and chrome with the same result  any help much appreciated
