forum
Message 1 of 5
Trying to set up remote webcam software
Im trying to set up yawcam so I can view my webcam from anywhere.
Yawcam gives me the address http://109.xxx.xxx.xxx:8081 to view from another computer.
When I try to open this address I am presented with a box that says:
Sign in to 109.xxx.xxx.xxx:8081 "HuaweiHomeGateway"
Name:
Password:
I have tried entering my router user+pass but it won't accept it.
I wouldn't think that it's a user+pass for the modem as that is just used to hook up to the cabinet.
Yawcam and my router both support UPNP so I shouldnt have to manually forward the port 8081, but nevertheless I have done anyway, and still no luck
4 REPLIES 4
forum
Message 2 of 5
Re: Trying to set up remote webcam software
I sorted it. I changed the port in Yawcam then I set up a User-defined Application in Port Forwarding>Supported Applications, then assigned that application to my PC in Port Forwarding>Configuration
DeanM
Moderator-Retired
Message 3 of 5
Groovy, I'm glad to hear it 🙂 I had a bit of an essay written up but I was a tad wide of the mark if all you needed to do was forward ports!
Dean
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
forum
Message 4 of 5
Cheers anyway fella 😄 I appreciate it
john46
Message 5 of 5
HI Like Dean I had some ideas but glad you have solved the problem and all is ok now 🙂
