Message 11 of 15
Re: Trying to use Netgear D6300 with BT Infinity. Any help?
Looking at the full specification.
  • Broadband Internet service
    - ADSL2+ Broadband Internet Service
    - Cable or Fibre: Connects to cable modem via Gigabit Ethernet WAN port
So it does appear to be dual function, so yes, it should work in that case.
Newbie
Message 12 of 15
Is there any way to cut out using the HH3 completely as the D6300 has all the functionality of the HH3 as well as the BT Modem? Or is the Hub a required thing with BT Infinity and leaves no way around its use?
Message 13 of 15
Soapy gave you the answer in message 4
Use the WAN connection on the router to connect the router to the Openreach modem. Go into the router settings and make a PPPOE connection from the it to the modem.
The username is bthomehub@btbroadband.com and any password will do.
Expert
Message 14 of 15
you must use the openreach modem, you will basically be removing the HH3 and replacing it with the netgear D6300
Message 15 of 15
Hi I have a D6300 and it does connect to Infinity as described here using the WAN port, however it will not allow you to receive BT Sport! I thought that I had cracked it with this thread by going through a HH3, however I cannot define the gateway and DNS for the HH3 in the D6300 settings and assume that this is blocking my progress.  Does anyone have a work around at all? I also have a Buffalo WZR-HP-G450H cable router which I thought I would be able to use but I cannot even get Infinity with that so sadly it is looking like yet another router will be required!
Any assistance would be appreciated.
P.S.  If I do crack the HH3 issue do you think that using the HH5 would replace both the modem and HH3?
Regards
