Message 1 of 4
Turn Bt smart hub into an AP for existing Smart Hub 2
Hi,
I have a smart hub 2. however, as many know you cant split the 2.4 and 5ghz channels on different SSID.
I have an old smart hub 1, which I'm thinking I could use as an AP to just broadcast an SSID exclusively for the 2.4ghz channel. rather than spending money on an new AP
Has anyone ever done this?
Thanks,
3 REPLIES 3
Message 2 of 4
Re: Turn Bt smart hub into an AP for existing Smart Hub 2
Countless people.
Just give it an IP address outside of the DHCP range of the master hub, turn off DHCP and connect the 2 together LAN port to LAN port.
Anonymous
Not applicable
Message 3 of 4
I'm not sure it will work as an AP as I suspect it will throw a wobbly during boot-up when it can't find a WAN connection but if you want to try it, set it as follows
Set a static IP address, you can't use 254 as that is your SH2, I suggest you use 192.168.1.1.
Disable the DHCP server (you don't want two DHCP servers on one Sub-net.)
If you want, set the Wi-Fi SSID and password to clone the SH2
Connect the Hub 6 and SH2 by Ethernet connection Lan to Lan
Edit: Dash it! that's twice in one day I've duplicated a reply from another user
Message 4 of 4
It will work just fine, although it will keep flashing purple or orange because it has no DSL input
