Message 1 of 6
Tv package channels
I am looking to get a bt tv package. If I was to get the entertainment package are the channels from the classic package also included in this entertainment package?
5 REPLIES 5
Message 2 of 6
Re: Tv package channels
No, you only get what's listed in the Entertainment Pack
Message 3 of 6
If I wanted channels in both what could I do. do they do other packages
Message 4 of 6
Nope. If you have a Flexible NowTV pack, you can't have classic and visa versa.
The other option is to take the classic pack through BT and buy your NowTV passes direct through NowTV. Doing it this way means you'll not have the NowTV channels through the EPG and won't be able to record them and will have to watch through the NowTV app.
Message 5 of 6
Thank you for your help. May have to rethink it
Message 6 of 6
You could take the Classic Entertainment Pack and buy passes through Now TV. This will allow you to "nearly" have the best of both. BTTV via the EPG on the box, and Now TV through the Now TV app on the box. The trade off is that the Now TV channels aren't on the EPG and so non recordable. The plus side is that you can pick up Now TV passes quite cheaply online. This is what I do as a lot of stuff is on demand on Now TV anyway.
