you can check your exchange here http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
if nothing shown then can you post the adsl stats from your router if you can connect long enough
is quiet line test ok? dial 17070 option 2 best done with corded phone
No outages in the area on those links. Thanks for that.
Line test seemed ok. Have cordless so can hear myself breath down the phone! lol
It is running a little now... adsl:
Line state | Connected |
Connection time | 0 days, 0:05:45 |
Downstream | 2,269 Kbps |
Upstream | 440 Kbps |
VPI/VCI | 0/38 |
Type | PPPoA |
Modulation | ITU-T G.992.5 |
Latency type | Interleaved |
Noise margin (Down/Up) | 13.8 dB / 25.0 dB |
Line attenuation (Down/Up) | 41.0 dB / 21.9 dB |
Output power (Down/Up) | 0.0 dBm / 13.2 dBm |
Loss of Framing (Local) | 0 |
Loss of Signal (Local) | 0 |
Loss of Power (Local) | 0 |
FEC Errors (Down/Up) | 98 / 4294966873 |
CRC Errors (Down/Up) | 0 / N/A |
HEC Errors (Down/Up) | N/A / 0 |
Error Seconds (Local) | 0 |
21:48:56 26 Jan | KERNEL Controlled restart |
21:45:25 26 Jan | CONFIGURATION saved by TR69 |
21:44:54 26 Jan | FIREWALL event (1 of 1): deleted rules |
21:44:54 26 Jan | PPP link up (Internet) [86.183.170.245] |
21:44:53 26 Jan | PPP CHAP Chap receive success : authentication ok |
21:44:53 26 Jan | PPP CHAP Receive challenge (rhost = bras-red3.gi-b) |
21:44:44 26 Jan | FIREWALL event (1 of 1): modified rules |
21:44:44 26 Jan | FIREWALL event (1 of 1): created rules |
21:44:44 26 Jan | xDSL linestate up (ITU-T G.992.5; downstream: 2269 kbit/s, upstream: 264 kbit/s; output Power Down: 19.6 dBm, Up: 12.9 dBm; line Attenuation Down: 42.0 dB, Up: 22.7 dB; snr Margin Down: 6.0 dB, Up: 11.4 dB) |
21:44:19 26 Jan | xDSL linestate down |
21:44:03 26 Jan | xDSL linestate down |
21:43:43 26 Jan | xDSL linestate down |
21:43:26 26 Jan | FIREWALL event (1 of 3): deleted rules |
21:43:26 26 Jan | xDSL linestate down |
21:42:54 26 Jan | FIREWALL event (1 of 2): modified rules |
21:42:54 26 Jan | FIREWALL event (1 of 2): created rules |
21:42:54 26 Jan | xDSL linestate up (ITU-T G.992.5; downstream: 2269 kbit/s, upstream: 328 kbit/s; output Power Down: 19.6 dBm, Up: 12.7 dBm; line Attenuation Down: 42.0 dB, Up: 22.7 dB; snr Margin Down: 6.0 dB, Up: 10.9 dB) |
21:42:35 26 Jan | xDSL linestate down |
21:42:27 26 Jan | PPP link down (Internet) [31.52.146.81] |
21:42:22 26 Jan | xDSL linestate down |
21:42:05 26 Jan | xDSL linestate down |
21:41:41 26 Jan | xDSL linestate down |
21:41:18 26 Jan | FIREWALL event (1 of 2): deleted rules |
21:41:17 26 Jan | PPP link up (Internet) [31.52.146.81] |
21:41:17 26 Jan | FIREWALL event (1 of 2): created rules |
21:41:17 26 Jan | PPP CHAP Chap receive success : authentication ok |
21:41:17 26 Jan | PPP CHAP Receive challenge (rhost = bras-red3.gi-b) |
21:41:01 26 Jan | FIREWALL event (1 of 2): modified rules |
21:41:01 26 Jan | xDSL linestate up (ITU-T G.992.5; downstream: 2269 kbit/s, upstream: 216 kbit/s; output Power Down: 19.6 dBm, Up: 12.5 dBm; line Attenuation Down: 42.0 dB, Up: 22.9 dB; snr Margin Down: 6.4 dB, Up: 10.3 dB) |
21:40:48 26 Jan | PPP link down (Internet) [86.174.160.27] |
21:40:38 26 Jan | xDSL linestate down |
21:40:14 26 Jan | xDSL linestate down |
21:40:02 26 Jan | FIREWALL event (1 of 2): created rules |
21:40:02 26 Jan | FIREWALL event (1 of 1): deleted rules |
21:40:02 26 Jan | xDSL linestate down |
21:38:40 26 Jan | CONFIGURATION saved by TR69 |
21:38:09 26 Jan | FIREWALL event (1 of 1): deleted rules |
21:38:08 26 Jan | PPP link up (Internet) [86.174.160.27] |
21:38:08 26 Jan | PPP CHAP Chap receive success : authentication ok |
21:38:08 26 Jan | PPP CHAP Receive challenge (rhost = bras-red3.gi-b) |
21:38:03 26 Jan | FIREWALL event (1 of 1): modified rules |
21:38:03 26 Jan | FIREWALL event (1 of 1): created rules |
21:38:03 26 Jan | xDSL linestate up (ITU-T G.992.5; downstream: 2269 kbit/s, upstream: 440 kbit/s; output Power Down: 19.8 dBm, Up: 12.9 dBm; line Attenuation Down: 41.5 dB, Up: 21.9 dB; snr Margin Down: 19.8 dB, Up: 12.5 dB) |
21:37:39 26 Jan | xDSL linestate down |
21:37:15 26 Jan | xDSL linestate down |
21:36:59 26 Jan | FIREWALL event (1 of 2): deleted rules |
21:36:59 26 Jan | xDSL linestate down |
21:36:39 26 Jan | FIREWALL event (1 of 2): modified rules |
21:36:39 26 Jan | FIREWALL event (1 of 1): created rules |
21:36:39 26 Jan | xDSL linestate up (ITU-T G.992.5; downstream: 2269 kbit/s, upstream: 227 kbit/s; output Power Down: 19.6 dBm, Up: 12.6 dBm; line Attenuation Down: 42.0 dB, Up: 23.0 dB; snr Margin Down: 6.0 dB, Up: 10.9 dB) |
21:36:15 26 Jan | xDSL linestate down |
21:36:13 26 Jan | PPP link down (Internet) [109.151.62.211] |
21:35:51 26 Jan | xDSL linestate down |
21:35:35 26 Jan | FIREWALL event (1 of 3): created rules |
21:35:35 26 Jan | FIREWALL event (1 of 1): deleted rules |
21:35:35 26 Jan | xDSL linestate down |
21:34:55 26 Jan | CONFIGURATION saved by TR69 |
21:34:51 26 Jan | SNTP Unable to contact server: 198.18.1.7 |
21:34:24 26 Jan | FIREWALL event (1 of 2): deleted rules |
21:34:23 26 Jan | PPP link up (Internet) [109.151.62.211] |
21:34:23 26 Jan | PPP CHAP Chap receive success : authentication ok |
21:34:23 26 Jan | PPP CHAP Receive challenge (rhost = bras-red3.gi-b) |
At the moment
21:56:33 26 Jan | LOGIN User admin logged in on [HTTP] (from 192.168.1.64) |
21:56:26 26 Jan | LOGIN User Basic logged in on [HTTP] (from 192.168.1.64) |
21:53:04 26 Jan | SNTP Synchronised to server: 213.123.20.170 |
21:53:04 26 Jan | SNTP Systemtime update: time setting 00:04:04 > new time setting: 21:53:04 |
Have you tried connecting to the test socket at the rear of the master socket
Your speed has dropped due to an increased noise margin if you can try the suggestions below and post back we can advise further
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
also you could try the hints given by poster RogerB in this link they may help http://community.bt.com/t5/BB-in-Home/Poor-Broadband-speed/m-p/14217#M8397
Then someone here may be able to help and offer more advice.
This is a customer to customer self help forum the only BT presence here are the forum moderators
are you connected to the master or test socket? do you have other sockets apart from the master?
