Message 11 of 22
Re: UAS errors
No, because I can't get Ipv6 working on the Zyxel, which seems to be a problem with 3rd party routers in general.
Perhaps a Tp-Link VR 600 v2 would do the job some have got that working with IPv6, I think it has the same Broadcom chipset as the Zyxel, but the v3 uses a Mediatech.... or does it.... so much conflicting information.
Message 12 of 22
Re: UAS errors
Hmm, not sure why IPv6 is so important at the moment, there are extremely few IPv6 only sites.
Have you asked on the Kitz forum about configuring IPv6, there are a lot of Zyxel users on there?
Message 13 of 22
Re: UAS errors
At the moment I have the Zyxel in router mode with wifi off feeding a whole home premium mesh system which works really well, until BT reboot the hub. Previously I had complete wifi but had to ditch that because it kept switching the backhaul to 2.4ghz and the throughput dropped to 1mbps until I did a power off reset. So many annoying and expensive problems.
Message 14 of 22
Re: UAS errors
My problem is that I'm a perfectionist and like things to work properly. Kitz posters can mostly not get Zyxels working with BT, something about preceding characters and BTs implementation of Ipv6, hence wanting to stick with BT router.
Message 15 of 22
Re: UAS errors
Unfortunately, the SH2 won't play ball with the Zyxel in bridge mode. Maybe it's locked to BT modems?
I'll buy a S/H HG612 off ebay and try that. If that's not successful I'll have to get a 3rd party modem/router and hope for the best with Ipv6.
Thanks for your help.
Message 16 of 22
Re: UAS errors
Are you sure you have configured the Zyxel correctly, the SH2 doesn't care what modem you use. Did you set the vlan ID to 101 on the Zyxel.
Message 17 of 22
Re: UAS errors
802.1p set to 0   and  802.1q set to 101 on the Zyxel.
I had it working in bridge mode with a TP-Link TL-WR841N, it worked but IPv6 was intermittent so I had to return it. IPv6 works fine on the SH2 when using it's own modem.
Maybe I'm missing something on the SH2 but I factory reset, changed to FTTP, connected port 4 to port 1 on the Zyxel and it went orange and stayed there. There was no option to set MTU etc which was on the TP-Link.
Message 18 of 22
Re: UAS errors
That's weird, the SH2 should be agnostic to modem used. Unfortunately I have only tried it with an HG 612 so can't put hand on heart to say it definitely will work with any modem but I can't see how it doesn't, there's nothing special about the HG612
Message 19 of 22
Re: UAS errors
3rd party router suggestion (BT) (kitz.co.uk)
From the above, it looks like a TP-Link VR600 v2 (not the v3 AKA AC2100) may be the answer, what do you think?
Message 20 of 22
Re: UAS errors
Yes, TP Link seem to have sorted IPv6 with that model although they never did with the 9980 that I used to use.
