carabean
Message 21 of 29
Re: UHD Box keeps going into Maintenance Mode
Can anyone tell me whether the patch has been released and whether it has solved the problem, please?
Shanusanus
Message 22 of 29
DarrenW has this patch released yet and did it fix the constant going into Maintenance Mode?
DarrenW
BT TV Expert
Message 23 of 29
Hi @Shanusanus @carabean,
We are still working through the patch, the fix has been successful but we are just reviewing our test data before we decicde to roll-out the patch to all UHD boxes.
Once I have a software release date the patch will be part of, I will update the Forum post.
PatC1
Message 24 of 29
New customer here. Same issue. One week, 7 resets. Sigh.
PatC1
Message 25 of 29
Mine is not a UHD box btw, it’s a Youview+, same issue
Niko1
Message 26 of 29
Just hold on for about 4-6 months and it should be sorted. Just don't go on holiday. It always happens to me on holiday...
gcwj
Message 27 of 29
VERY frustrating. We have had this issue for several months now.
DarrenW
BT TV Expert
Message 28 of 29
Hang in there @gcwj !
We do have the fix confirmed in a software release soon.
On another forum thread we had a discussion about how we could try to mitigate the issue.
This has not been tested but if you change the Youview box's Power Mode to "Always Ready" it may avoid the problem.
DarrenW
BT TV Expert
Message 29 of 29
A fix is now being rolled out, softare version 31.106 has been rolled out to 30% of UHD users and will be 100% by 05/11.
I would appreicate feedback on whether this has or has not resolved your problems.
Thanks.
