Message 1 of 4
UHD Question
Just recieved the UHD box and the default quality setting is 8bit UHD. Would it make sense to only have that on for the UHD channels and standard 1080p for HD channels? Would it be detrimental to do so?
3 REPLIES 3
Message 2 of 4
Re: UHD Question
Hi i have a UHD box too - where are you finding these settings?
cheers
CG Over An Out
Message 3 of 4
Re: UHD Question
Click guide, setting then tv quality and change it. Not sure if UHD 8BIT is better then 1080p on standard HD channels. Seems a bit less clear
Message 4 of 4
Re: UHD Question
If you have the UHD box set up with a 4K TV then you should leave the settings at UHD 50 fps 8 bit. Your 4K TV should upscale the picture on HD and SD channels. Even better if you TV supports UHD 50fps 10bit then select this as it enriches the picture.
