TwoBit
Message 1 of 4
UHD YouView V3 Box
I've recently resubscribed to total entertainment package due to getting a new deal. This did mean having to accept a new box.
I've had the box for 2 weeks and its only plugged in via ethernet as I have a different setup for all other channels so it's mainly just left in stand-by until the football season starts.
Twice now I've got up and the blue light is on indicating the box is on, when I got to the bt box its asking for a software reset, now that does nothing as I don't get any channels back at all. To fix this I have to do a factory reset to get my subscription channels back.
Is anyone else having this issue ? I'm wondering if it a software issue or maybe the box ? My previous box I had no problems with at all.
Cheers.
3 REPLIES 3
JohnC2
Moderator
Moderator
Message 2 of 4
Re: UHD YouView V3 Box
Hi @TwoBit Sorry you lost your Internet channels and had to reset the box to get them back.
Is this issue still still happening? Post back and let me know.
Cheers
John
TwoBit
Message 3 of 4
Thank you John for your reply.
At the moment its hard to gauge as I've not had the box that long and don't actually use the box as I've only got it for the football. Like I said I only noticed a problem as the blue light was on each time.
If it happens again I'll get in contact as obviously indicates there is a problem of some nature. I was just seeing if anyone else was having the same issues.
Niko1
Message 4 of 4
It's happened to quite a few of us. There are a few more threads on here if you search. Nobody has offered any explanation! I got fed up of asking..
