borris12
Expert
Message 1 of 1,731
UPGRADE OF 40MB TO 80MB SPEEDS ?
any more news on a date for the proposed "FREE" upgrade of speed
from 40MB to 80MB on Infinity ?
any advise any one please
i currently get about 35MB
but does drop dramatically if i do much downloading as if being throttled on speed
1,730 REPLIES 1,730
MrBelter
Expert
Message 2 of 1,731
Re: UPGRADE OF 40MB TO 80MB SPEEDS ?
If you currently get 35Mbit then when an 80Mbit product becomes available you will get 35Mbit. The 17a profile which enables the higher speeds has been in place some months and if you aren't seeing 37.5'ish now (which is the current max) then you are getting as fast as you are going to get.
borris12
Expert
Message 3 of 1,731
if i do get 37.5 ish speed,  which i do get at times !!
i did a bt speedtest just and got 37.5MB
how do i test profile ?
does that mean i wll get the 80MB speed when upgraded ?
any news on when these speeds are to start please ??
dcullum
Message 4 of 1,731
What makes yo think that the 40-80 upgrade will be free?
borris12
Expert
Message 5 of 1,731
because Virgin upgrade was free
and if BT want to remain competitve they will also have to be free
or they will out price themselves
Webby
Message 6 of 1,731
not really
McGrath1982
Expert
Message 7 of 1,731
Hi borris12 go on the TalkTalk website enter your phone number and postcode you will find out what ***SPEED*** you will get on the 80/20. I sync at 39999 say and get 37.18Mbps and on the TalkTalk site they say I can get 71.1Mbps
Mister_C
Message 8 of 1,731
How does that make it a proposed "free" upgrade ? You're just making an assumption it's going to be free because Virgin aren't charging for it.
deathaxe
Expert
Message 9 of 1,731
Also Virgin have hurt themselves by all these "free" upgrades as they now have seriously overloaded a huge amount of nodes with no plan on how to ease local congestion.
dcullum
Message 10 of 1,731
...And as TalkTalk charge a different price for each sevice (40/80-£10/£15) I cant imagine that BT & others wouldnt too
