Webby
Message 1531 of 1,731
Re: UPGRADE OF 40MB TO 80MB SPEEDS ?
Could be a dodgy speedtest site or your antivirus. Kaspersky is known to give bizzare results.
BattFink
Message 1532 of 1,731
I'm presuming you're on FTTP? Looks like Infinity Option 3 speeds
deano3693
Message 1533 of 1,731
Anybody know how long the 80mb upgrade takes after you have received the Thank you for your order is we don't confirm your order by email or letter within 5 days please call this number ..... as it hasn't appeared in MyBT yet ?
IT SUPPORT TECHNICIAN - Comptia A+ Certified, MTA Qualified and MTSC qualified
peapod
Message 1534 of 1,731
Hi
After speaking to BT the 2nd time(was supposed to get a call within 3 days...yeah right) I am now told im still in migration period.  I think they are passing the buck.
So, im still on 37/8......I have emailed the mods still no reply....
Mister_C
Message 1535 of 1,731
@peapod wrote:
Hi
The Mods can take up to three working days to reply.
nayan89
Message 1536 of 1,731
Just got off the phone to BT, was told the same old malarkey about 10 day period, when I was told on the previous call 24-48 hours. This time they've told me they are going to reset my line to try and get it sorted within the next 24 hours. They said they'll call me back tomorrow evening too to get an update and have taken the persons name down so it sounds a bit more promising this time considering they promised it'll be sorted now.
sahotaquack
Message 1537 of 1,731
Ive still got 38mb and 9.5mb showing on MyBT?? I upgraded on the first day available.
Mister_C
Message 1538 of 1,731
I'm a bit baffled with my speed results. When I had the upgrade done last Friday my IP profile was approximately 72.19 Mbps ( I can't remember the actual number ). I was getting download speeds of around 70 Mbps. The last couple of days my speed has gone down to around 62Mbps. I just checked my IP profile and it's now saying 64.85 Mbps. The estimate in the BT checker before the upgrade was 63.5/20. Does this all sound right. I don't understand why my IP profile has been reduced. Is this an indication of a problem ?
chrisdman
Message 1539 of 1,731
Hi everyone,
Got enabled in the early hours of this morning, was getting 38/8 before and now getting 40/14.
I was expecting to get more....
I have re-booted the router as advised but still getting the same results.
Any ideas if it will jump up to the expected 60/70+
Thanks,
Chris.
Webby
Message 1540 of 1,731
Like ADSL, when your line initally connected on the new up to 80 profile the SNR would have been set to 6. More than likely some "noise" has been detected by DLM so it's increased your SNR margin which has brought your connection rate down. DLM favours stability over speed. You're at what you were estimated  - just enjoy it 🙂
