Davidwalker600
Message 1581 of 1,731
Re: UPGRADE OF 40MB TO 80MB SPEEDS ?
Download Speed: 72585 kbps (9073.1 KB/sec transfer rate)
Upload Speed: 15011 kbps (1876.4 KB/sec transfer rate)
Latency: 17 ms
17 April 2012 22:02:28
this is the speed test from virgin media speed test
http://www.vmspeed.com/
Date of Speed Test:Download Speed:Upload Speed:
2012-04-17 22:08:43
74981 kbps (9372.6 KB/sec transfer rate)
15872 kbps (1984 KB/sec transfer rate)
thats from http://www.speedtest.bbmax.co.uk
and my upgrade is today
ukdeveloper
Message 1582 of 1,731
Well, they got 1 hour 45 mins left to upgrade me, or let me down....
I know which one my monies on.
UKD
Alan63
Expert
Message 1583 of 1,731
@borris12
Last Result: Download Speed: 36066 kbps (4508.3 KB/sec transfer rate)
 Upload Speed: 7632 kbps (954 KB/sec transfer rate)
Latency: 16 ms 17 April 2012 21:24:46
do you think this is pretty niftie without having to upgrade ?
____________________________________
Yep at those speeds you'll have great user experience. Always pays to work out exactly what you need broadband to do. even watching films etc will only use a part of what your getting.  if your needs change later ,well then reconsider.
However, if you could get (say) 20% more at NO cost - why not?
I presently get very similar speeds to you - I'm upgrading on 19th - i'll let you know how it goes.
Dicka5
Message 1584 of 1,731
I'm having an issue with upload speeds via Ethernet on my PC...
My download speed is averaging 75mb on all speed test websites. However my upload is 7.5 on them all.
The upload on my iPad shows the full 20mb upload... I've tried the firewall and routers settings but no such luck.
Any ideas?
ukdeveloper
Message 1585 of 1,731
Well my order seems to have disappeared from the BT web site in the last 30 minutes. Don't know if this is a good thing or a bad thing.
No apparent increase in speed though, even after a modem reboot.
UKD.
borris12
Expert
Message 1586 of 1,731
please let me know how you go
wiesiek1979
Message 1587 of 1,731
Hi.Just to want share with you about my try to upgrade.
I place d the order on Thursday 12/04 via online form.I had confirmation that BT received order and on my account was showing it will be complete on Friday 13/04 till midnight.That never happen.Later in the evening i received the message,they have difficulties with my order,and need to investigate,will back to me on Tuesday(today).Till 4 PM i don't have replay from bt,so i phone them.Nice ladie told me they need 2 more days to investigate,because its up to some bt suppliers.This suppliers told them I'm not able have higher speed,which is not true.My estimated is 79,9 up and 2 down.Dont know what to think about it.
jocat0
Message 1588 of 1,731
Mine is a different problem. I have upgraded Bt speed checker said 31/6 ip profile is still stuck at 29/5. BT open reach engineer came over weekend as I complained of a fault which he did find and he checked my line with his machine and said my max achievable was 51/7.9. So go figure!!
ukdeveloper
Message 1589 of 1,731
As expected..... no upgrade.
supposed to be 17th as of yet nothing.
Order even disappeared from the website.
Going to Sky.
UKD
jonstatt
Message 1590 of 1,731
Hmm this is odd.
The maximum you can get on Infinity 40MB on a speedtest is 37.5 right?
This morning, following my order request, I have now got a tiny boost and consistently get 38. This means I must be on the new speeds.
But on speedtester.bt.com my profile is still 38.71?!
How can I be getting a true 38 download speed and still have a profile of 38.71? *confused*
EDIT: Restarted the router (not the modem), and now I am getting 42Meg actual download speed on speedtester. So the profile was clearly stuck. I bet my BT vision is going to cause problems with this again. I have had issues with sticky profiles.
