Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
Mine has standard mains sockets on the front, but it looks like the one you are thinking about has IEC sockets on the back, which it a bit inconvenient, as you will have to chage the plug as you say.
This would be a better one, as its the same design as mine.
I have the APC Back-UPS ES 550 UPS AC 230 V 330 Watt 550 VA 8 Output Connector(s)
@cameron1590 wrote:
Hi, Thanks for the info have found a few of these so will look into it more. Would you recommend what some other guys have done with these ? Where they connect up two marine batts instead of the two small internal batts ? I have not really got the space at the moment but just wondered for future upgrade purposes. Cameron
I would not recommend this, as the unit is not designed to operate for a long time, and may overheat.
It would also invalidate any guarantee.
