Frosted16
Message 1 of 8
Ultra HD box resetting aprox 10mins
Hi guys, got a Ultra HD box that has decided to start resetting itself on aprox 10min mark of active use. I have not yet done a factory reset however wondering if there is a heat issue here?
Open to suggestions....
David
7 REPLIES 7
zulu17
Distinguished Guru
Distinguished Guru
Message 2 of 8
Re: Ultra HD box resetting aprox 10mins
Hi  @Frosted16  welcome t the community/
Can you be a bit more specific about what occurs  ie what precisely happens  , ie when you say reset what actually happens , what screens come up?
Also how long have you been using this Youview box  ?
Frosted16
Message 3 of 8
Pretty much since they were released! And no screens pop-up - simply a reboot or restart. Have to give it a moment or two too fully catch itself up and then turn it back on
David
JohnC2
Moderator
Moderator
Message 4 of 8
Hi @Frosted16 Sorry you are having a problem with your UHD box
Have you tried a reset yet?
You have mentioned a heat issue. Do you hear the fan coming on alot on the box. Also is the box in an well ventilated area?
Cheers
John
Frosted16
Message 5 of 8
John - was away on the weekend, will be trying the Reset tonight [I may also give the box a hoover just to be on the safe side]
David
JohnC2
Moderator
Moderator
Message 6 of 8
Hi @Frosted16 Post back and let us know how you get on.
Cheers
John
Frosted16
Message 7 of 8
All
Reset the box - full new install and updated as of so far... were good - thanks for taking the time to reply!
Regards
David
JohnC2
Moderator
Moderator
Message 8 of 8
Hi @Frosted16 Thanks for the update and good to hear that the issue is resolved.
cheers
John
